Since the DashHawk only appears to read and not write...on my SRT8.
Can I hook it up in tandem with my Predator Programmer?
I have an ODII "Y" cable and want to be able to hook up the programmer without unplugging my DashHawk.
Will this work?
DashHawk info...
http://www.dashhawk.com/
Predator with DashHawk
2006 Charger SRT8
Inferno Red with All Factory Options / Groups
Side moldings and rear ram's head shaved, Diablosport Trinity 2 Platinum, Billett Technology bling
MPR Motorsports built 6.1 based/392 NA Stroker, BBK 85mm TB, TranZformer, Kooks Long Tubes, 3.70 LSD Hellcat rear cradle
RE: Predator with DashHawk
I've got the same exact setup you have. I wish I could say it works, but for some reason it doesn't. The Predator says it can't read the PCM when the Dashhawk is hooked up. I still have the "Y" cable hooked up, as it makes it easier to switch between the DS and the DH without fumbling around for the stock plug. I tuck them both up behind the lower panel, one with the DS plugged in, and the other has nothing plugged in. No problems. Maybe one of the DS gurus can come on and tell us why it doesn't work, and if there is a way to make it work.
I guess the Predator doesn't know what to do with the DashHawk communications. Or most likely the DashHawk "Owns" the comm requests as the PCM probably doesn't "share" comm requests.
2006 Charger SRT8
Theres probably too much info being sent on the bus.
The DashHawk tries to limit itself to 2%? (maybe it's 5%?) of bus utilization. I don't know what mechanism they use to do that.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
Quick (<-- haha) update. DashHawk (Ken Mosher) is speculating that you guys are both using the same ID on the bus. Any possibility you can coordinate with them?
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
Re: RE: Predator with DashHawk
x2Quick wrote:Quick (<-- haha) update. DashHawk (Ken Mosher) is speculating that you guys are both using the same ID on the bus. Any possibility you can coordinate with them?
2006 Charger SRT8
