Tune for 6.2L 8 spd 1500?
Recently attempted to tune my 2015 6.2L 8 Spd Silverado but was unable to load the factory tune from vehicle after a few attempts i gave up. Has anyone else had this problem? Also was reading people were waiting on the tune for the 8spd to be released. New user and new to tuning.
White Denali
Re: Tune for 6.2L 8 spd 1500?
Make sure to pick manual transmission when you select your vehicle as the 8 speed is not yet supported yet and the tuner will lock up on you. If you select automatic this is your problem.
This...White Denali wrote:Make sure to pick manual transmission when you select your vehicle as the 8 speed is not yet supported yet and the tuner will lock up on you. If you select automatic this is your problem.
Options/change transmission type, select manual.
