Neutral/Park rev limiter 2015 charger rt
Posted: Sat Oct 08, 2016 12:16 am
Hi there,
I just recently got the diablosport trinity and PCM for my 2015 charger RT. I loaded the canned 91 octane tune and the only parameter I modified was the neutral/park rev limiter to +600. After the tune installed I started the car to find that it's surging really badly in idle. The RPM will spike up and down by about 500-800. I reset the modified parameters and installed the regular 91 tune and it was fine again. I repeated this process to make sure that nothing went wrong with the first time I wrote it and it happened again.
After searching the forums I have found that there are other cases of this happening where you guys said you were working on a fix. That was back in March and I'm wondering if there is any way to remedy this issue as of yet?
