2003 DENALI WONT CONNECT TO PCM
Posted: Tue Oct 18, 2016 12:47 pm
by squatch422
Already tried programmer on 2008 SS Impala, no problems, but it seems that on this vechicle it won't connect. this also happened on a 2004 Escalade...Any thoughts?
Re: 2003 DENALI WONT CONNECT TO PCM
Posted: Tue Oct 18, 2016 1:32 pm
Anything aftermarket installed in the truck? i.e did not come from the factory?
make sure anything aftermarket is disconnected/pull the fuse for - anything like aftermarket stereo, subs, amps, nav, alarm, remote start, seat heaters, trailer brake/light setup, etc.. anything like that, their wiring harnesses need to be disconnected/pull the fuses for it before you try to tune anything...
also make sure everything is turned off inside the truck.. lights, radio, heat/fan/blower, do not operate power windows, put your parking brake on, etc...
Posted: Tue Oct 18, 2016 2:47 pm
by squatch422
I am totally honest when I say, this truck is 100% stock, no exhaust, no CAI, no stereo (other than factory) All the power is turned off in side. door closed. All is done with the exception of the parking brake...and nothing happens.
Posted: Tue Oct 18, 2016 3:10 pm
if the trinity talked to the 08 Impala SS, you need to go to options/change vehicle type and select the 04 Escalade or 03 Yukon to change the application from GM CAN to GM J1850, then it should work.
