I recently acquired an intune for my 2007 impala ss. I've encountered a couple of oddities I'd like a little input on.
The first being when I apply a tune, I receive an error about parameters unable to be initialized or read, but continuing through the error applies the tune successfully. What does this error mean and should I be concerned about anything?
Second, when logging I've noticed that after about 10, minutes the logger will freeze and stop logging data. I am able to exit logging and save the log, but no info after the 10 minutes is available when looking back at the logs. Is this intended operation and how can I fix this if it isn't.
Thanks in advance!
Logging freezing
Re: Logging freezing
1. Use advanced tune
2. The tool will only log for so long, depending hw many pids you are recording, if you want long logs best to bring a laptop and stream directly to the PC.
