on a 2012 challenger is there a PID for fuel pressure? ( I don't see one listed or do I need an update)if not what sending unit do you guys use and how to hook it up?
Fuel pressure
Re: Fuel pressure
So no one has any info on adding analog fuel pressure input to the trinity
Re: Fuel pressure
dose the trinity analog hook up supply the 5 volt power for the sending unit??? or would I need s stand alone 5 volt supply for it??
Re: Fuel pressure
you can use a 5v sender to display it on the device if needed. The PCM does not always monitor or display fuel pressure.
