kooks + corsa tune ???
i have on my car a kooks full system and a corsa system and a dub air intake is there any specil tune i can get and thank you
RE: kooks + corsa tune ???
I would just use the CAI tune.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
i think he has LT headers by kooks ! running a cannned CAi 93 tune would be making him lean right ?
im asking cos i have done mopar LT headers today and need the same advice (i have mopar catbacks and mopar CAI)
thanks....pz reply at earliest ...im waiting to WOT the car to hear the new growl but am refraining cos i dont have a/f meter or a dyno where i live
Without knowing the actual A/F there is no way to tell if it is lean or not.
You may need to consider a wideband.
- HighHorseman
Adding my $0.02. I know in the cold winter air, we've had to add as much as 6.5% fuel in certain areas of the rpm band to the 93CAI tune on some SRT-8's to get the a/f ratio back down to the 6.1L's sweet spot. They technically don't run lean (above 13.0) without the additional fuel but with the headers and high flow cats they're definately out of their sweet spot. This additional fuel probably only applies in cold, 50 degree or below, air. On a 80 degree day I'd be surprised to see any fuel needed.
Joshua, HHP
Joshua, HHP
so what exactly are the sweet spots for AFR on a 5.7 charger RT ?
i know a tuner who said that in hot weather (temps of 45-50 C) switch back to stock tune rather than canned tunes...is this true ?
- UARPerformance
Re: RE: kooks + corsa tune ???
zohaer21 wrote:so what exactly are the sweet spots for AFR on a 5.7 charger RT ?
UAR Performance.com
- UARPerformance
RE: Re: RE: kooks + corsa tune ???
Guess I did an opps!!:>) Anway 12.5 to 12.8 seems to be very happy. I would do a custom tune for summer. Make sure no knock retard happening.
UAR Performance.com
Actually the Hemis seem to like the low 12:1 range.
- UARPerformance
12:1-12.5:1 is ideal across the board.
