ISSUE WITH PCM CALID
PLUGGED TUNER INTO VEHICLE GAVE ME MESSAGE SAYING PCM NEEDED CALIBRATION UPDATE. I PLUGGED INTO PC CAME ON HERE AND FOUND THE 1R04I UPDATE WHICH I APPLIED TO THE DEVICE ALONG ALSO WITH A TUNE UPDATE I THINK NOT SURE WHICH I DROPPED INTO THE TUNES FOLDER. IT UPDATED, WONDERING IF THERES ANYTHING ELSE I NEED TO DO.
Re: ISSUE WITH PCM CALID
do you have access to a pc to update the device using the intune updater program?jryoshi wrote:PLUGGED TUNER INTO VEHICLE GAVE ME MESSAGE SAYING PCM NEEDED CALIBRATION UPDATE. I PLUGGED INTO PC CAME ON HERE AND FOUND THE 1R04I UPDATE WHICH I APPLIED TO THE DEVICE ALONG ALSO WITH A TUNE UPDATE I THINK NOT SURE WHICH I DROPPED INTO THE TUNES FOLDER. IT UPDATED, WONDERING IF THERES ANYTHING ELSE I NEED TO DO.
If not save the attached file to the root of the drive then let it import it then go to vehicle and try again, if it asks for another update there run the updater or post the info file here.
mikel wrote:do you have access to a pc to update the device using the intune updater program?jryoshi wrote:PLUGGED TUNER INTO VEHICLE GAVE ME MESSAGE SAYING PCM NEEDED CALIBRATION UPDATE. I PLUGGED INTO PC CAME ON HERE AND FOUND THE 1R04I UPDATE WHICH I APPLIED TO THE DEVICE ALONG ALSO WITH A TUNE UPDATE I THINK NOT SURE WHICH I DROPPED INTO THE TUNES FOLDER. IT UPDATED, WONDERING IF THERES ANYTHING ELSE I NEED TO DO.
dragged the file into the intune folder it updated. went back to car and it still says the same thing. can you please lead me to where i can download the intune updater program? cant find where to download. here is the info file once again and also a screenshot of tuner
the updater is on the diablosport cd rom drive when you connect it to your pc.
mikel wrote:the updater is on the diablosport cd rom drive when you connect it to your pc.
everything worked fine after using updater i went back to car and calibrated pcm.... NOWWWW onto my next issue seems like this tuner is still married. says vin is not licensed and no remaining open licenses... what can i do about this and how much is the fee to unlock? or should i just return it? (ebay)
$159 to reset the device by calling in with it powered up.
