Got around to tuning my 08 F150 5.4, and decided to go with the basic 87 can tuned, I went through all steps and didn't adjust any parameters, then after everything was done I went in to check the gear ratio and it is set on 3.73. I tried to then adjust it to 3.55 (my stock ratio) but it only has the 3.33 and 3.73 options. Anyone else have this problem?
Thanks,
Austin
Incorrect Gear Ratio Selection
Re: Incorrect Gear Ratio Selection
what tool is it?
fwiw, there is no need to adjust the gear setting if you have stock gears, the device knows what they are
