Vehicle not supported even after update
Posted: Sun Dec 25, 2016 9:58 am
by maxo64
Hi all,
I got the "calibration update required" message then "vehicle not supported" last night, on my 2013 charger SXT.
I plugged it in a computer and updated the calibration but still I got the "calibration required" message.
I updated the firmware too with no success so far.
Any idea how to fix this? info file attached.
Re: Vehicle not supported even after update
Posted: Tue Dec 27, 2016 2:46 am
by maxo64
Help anyone?
Posted: Wed Jan 04, 2017 9:17 am
did you take the vehicle to a dealer without restoring the stock tune?
Posted: Wed Jan 04, 2017 11:18 am
by maxo64
Yes, the dealer called for a recall to fix the spare tire and something else 2 weeks ago. But I don't know if they reflashed the ECU.
Posted: Wed Jan 04, 2017 2:22 pm
they did...this is why you must always restore when going to the dealer or they will flash it and lock you out.
Please give us a call with the tool powered up so we can reset the device.
Posted: Wed Jan 04, 2017 5:11 pm
by maxo64
Done. It worked perfectly.
Thank you so much Mike.
Posted: Sat Jan 14, 2017 10:56 am
by tt.personalaccount
What did he say to do? My new Diablosport is doing the same thing.
2006 Chrysler 300C 5.7L
Posted: Mon Jan 16, 2017 10:25 am
tt.personalaccount wrote:What did he say to do? My new Diablosport is doing the same thing.
did you go to the dealer without restoring the stock tune first?
Posted: Mon Jan 16, 2017 12:52 pm
Thanks Mike. I haven't been to the dealer in nearly a year. A couple years ago they replaced the motor for me if that helps figure this out any. This is the first time I have tried a Diablo (or any other device) on the car.
Posted: Mon Jan 16, 2017 1:04 pm
My info.xml file:
<?xml version="1.0"?>
-<tool_info>
<registration updates="0" tool_oem="DIABLO_D" status="0" sn="14U7Z5MO4R"/>
-<applications count="5">
<application rev="2r01n" name="vehicle"/>
<application rev="2r01c" name="updater"/>
<application rev="2r01i" name="gui"/>
<application rev="2r01d" name="installer"/>
<application rev="2r01a" name="logger"/>
</applications>
-<databases gui="2r01f" vin="2r01g" dtc="2r01a" dbnames="2r00">
<database pid="2r01cc" tune="2r01f" mfr="DCX"/>
<database pid="2r01cf" mfr="FORD"/>
<database pid="2r01ba" mfr="GM"/>
</databases>
-<system rev="1r01a" config="1r01d">
<option name="Wifi" driver="v4.0.2_9000.20130911" enabled="true"/>
</system>
<last-connected vin="2C3KA63H26H455094" mfr="DCX" calid="05094779AL"/>
<last-connected calid="04692392AIke0v0"/>
<licenses tuned="0" available="1"/>
<reg reg="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"/>
</tool_info>
Posted: Mon Jan 16, 2017 4:07 pm
I didnt have it in "Run"
Posted: Tue Jan 17, 2017 1:09 pm
OK, so you are good to go now?
Posted: Tue Jan 17, 2017 7:52 pm
Sure am. Thank you Mike
Posted: Fri Jan 20, 2017 7:35 pm
by pdimarco
Can I get the same help? I have the latest update and still get this issue and the dealer updated my PCM without my knowledge. I had the car there for a Alternator and when I picked up the car I saw they updated the PCM.
What can I do now?
Posted: Wed Apr 05, 2017 10:36 pm
by natejfields
im having same exact issue. i dont remember if i restored back or not. had airbag recall on my charger and he told me they flashed or updated cars computer. now i get the calibration update message. no new updates available for the intune.
