Modifying Tune. Lean/Rich
Posted: Sun Dec 25, 2016 1:40 pm
by SeaRay45db
I have Yukon Denali with a 6.0 L. After I put a CAI on I started throwing P 0171 and P 0174 codes. I know I don't have a leak, because I have to change brands because of other issues. When I put a time only, still get them. Taking with others, they have said just change the mix.
Now this sounds silly, but just to confirm, when I want to burn richer, or add more fuel, I would add 5%? Reason I ask, is I thought someone told me is that on the I2 you actually move the needle towards leaner if you are burning leaner to get the mix right.
Thanks!
Re: Modifying Tune. Lean/Rich
Posted: Tue Jan 03, 2017 5:55 pm
you should use the injector slope adjust to dial it in, see the sticky thread in the predator section for how to use the tool to log and adjust.
