I need help badly!! I have been without a truck for over a month now. I drive a 2005 Ford F-150 fx4 5.4L. To start with I was reinstalling a diablo sport canned tune on the truck which I've done numerous times and there was an error while tuning and the truck became disabled with no codes and it wouldn't turn over at all. Long story short I sent the PCM off to diablo to have it repaired.
When I received the pcm back the truck would turn over but not start so I checked the codes and got a p2101 and a p2107. I figured that it was poor reflashing or programming so I sent the computer back to diablo. Diablo then sent it back stating it was repaired and I had the same issue.
This time after sending the pcm back again they shipped me a new pcm. I installed the new one and to my surprise had the same issue of not cranking and same 2 codes.. I then started thinking maybe it isn't the pcm so I replaced the throttle body and TPS and that still didn't fix the issue.
Sorry for such a long post, but my question now is do you guys think it is a PCM issue or something that shorted or messed up originally when there was an error while tuning? Thanks for any help
PCM or issue within the truck
Re: PCM or issue within the truck
id get it to a dealer to have it all reprogrammed in the vehicle.
BigRed072310
I was wondering if the ford PATS could be causing the issue like if it wasn't reprogrammed when diablo reflashed it. Are you saying for me to take it to the dealer and have them re flash the software on the computer?..doesn't diablo cover some of the towing and reflashing?..does anyone know how long it takes to be reimbursed
Yes, if needed we'll cover up to $75 for the tow and $75 for the reflash.
BigRed072310
Thanks for the response..how does that work, do I need to email you guys a copy of the receipts?
Yes, call in and we'l give you some details to send the info over.
