2006 Dodge PowerWagon NOT SUPPORTED!
SUPERPOWERPHIL
I recently purchased a 2006 Power Wagon 6 speed stick and installed American Racing long tubes, Spectre air intake and a Magnaflow can. Now I go and purchase this sweet intune i2 and plug it in, no love, freaked me out when it didn't even turn over! Now I cant figure this out, why would it work on a auto truck but not a standard one. Kinda baffled and slightly annoyed at this. Is there anything you guys can do? Next year it gets a blower and new cam, really would love to have a tuner to make it all work, had another 06 but it was auto and it worked awesome with the Predator.
Phil
Comox BC
Canada
Phil
Comox BC
Canada
- 20161108_100039.jpg (448.47 KiB) Viewed 12548 times
be kind, be patient and work hard. The rest will take care of itself
2006 PowerWagon 6 speed stick
Spectre Performance-American Racing long tubes-Magnaflow can-Bilstein-inTune
supercharger and cam next summer!
Re: 2006 Dodge PowerWagon NOT SUPPORTED!
so you loaded a tune and it wouldnt start, then restored stock tune and it was fine?
SUPERPOWERPHIL
pretty much, then all it would do is the speedo correction reset codes and ABS. I'm not able to upload the performance tunes or adjust pedal sensitivity and such. Any ideas?
Phil
Phil
SUPERPOWERPHIL
Hi Mike, just wondering if you've had any success in finding a solution for my application. I hope this doesn't pose you and your team too much grief! Looking forward to hear from you guys.
Cheers!
Phil
Cheers!
Phil
Can you load a tune to the truck, then post the files from the i2 drive here, including anything in the tunes folder, as well as the info.xml file?
If it wont run please set it back to stock once you grab copies of those file.
SUPERPOWERPHIL
mikel wrote:Can you load a tune to the truck, then post the files from the i2 drive here, including anything in the tunes folder, as well as the info.xml file?
I'll try that, not sure on the process but I'll give it a shot, not the best at playing with these fancy boxes!
SUPERPOWERPHIL
here are the files that were on the tuner, hope this helps!
- runtime_17.dbg
- (4.36 KiB) Downloaded 425 times
- runtime_16.dbg
- (4.29 KiB) Downloaded 415 times
- runtime_15.dbg
- (27.31 KiB) Downloaded 445 times
- runtime_14.dbg
- (27.77 KiB) Downloaded 445 times
- runtime_13.dbg
- (23.3 KiB) Downloaded 432 times
- runtime_12.dbg
- (23.27 KiB) Downloaded 415 times
- runtime_11.dbg
- (33.94 KiB) Downloaded 438 times
- runtime_10.dbg
- (34.28 KiB) Downloaded 515 times
- runtime_07.dbg
- (98.35 KiB) Downloaded 438 times
- runtime_06.dbg
- (105.67 KiB) Downloaded 444 times
SUPERPOWERPHIL
here are the rest of the runfiles.
Cheers Mike!
Cheers Mike!
- runtime_21.dbg
- (4.51 KiB) Downloaded 408 times
- runtime_20.dbg
- (4.51 KiB) Downloaded 441 times
- runtime_19.dbg
- (4.46 KiB) Downloaded 429 times
- runtime_18.dbg
- (4.36 KiB) Downloaded 503 times
those are not tune files.. tune files will be in the TUNES folder...
SUPERPOWERPHIL
that folder is empty man, nothing in there. All that was in that inTune2 is on here except for the updater stuff.
as mike mentioned above.. install a tune to the truck, then post the files from the i2 TUNES folder here, including anything in the tunes folder, as well as the info.xml file... If it wont run, then restore it back to stock after you have grabbed copies of those files and posted them here.
SUPERPOWERPHIL
I tried that dude, won't let me install anything. The only function I can perform with the handheld is tire size adjust and ABS reset.
the initial issue you reported was that you load a tune and had issues, are you unable to load a tune again now?
SUPERPOWERPHIL
Not anymore, during the initial hook up with the truck it did load a tune but it messed with the trucks ability to run, turn over, anything. Now it just allows me to reset the ABS and sort out the tire size. At lease I can drive the truck, it still runs good and stuff, just cant load tunes or adjust the other parameters on it.mikel wrote:the initial issue you reported was that you load a tune and had issues, are you unable to load a tune again now?
what exactly happens when you try to tune it?
