Hi I just purchased a i2010 i2 tuner and it's saying not supported, I plugged it in for all the updates prior to attempting to run a tune, funny thing is that it reads the error codes and stuff
2013 ram 1500 5.7 with a 6 speed transmission
i removed my vin from the logs but here are the details
<tool_info>
<registration sn='14U7Z5LADZ' status='0' tool_oem='DIABLO_D' updates='0'/>
<applications count='5'>
<application name='vehicle' rev='2r01n'/>
<application name='updater' rev='missing'/>
<application name='gui' rev='2r01i'/>
<application name='installer' rev='missing'/>
<application name='logger' rev='2r01a'/>
</applications>
<databases dbnames='2r00' dtc='2r01a' vin='2r01g' gui='2r01f'>
<database mfr='DCX' tune='2r01f' pid='2r01cc'/>
<database mfr='FORD' pid='2r01cf'/>
<database mfr='GM' pid='2r01ba'/>
</databases>
<system rev='1r01a' config='1r01d'>
<option name='Wifi' enabled='false'/>
</system>
<last-connected vin='' mfr='DCX' calid='68153842AK'/>
<licenses available='1' tuned='0'/>
<unsupported calid='68153842AK' vin='' oem='DCX'/>
<reg reg='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'/>
</tool_info>
Vehicle not supported
Re: Vehicle not supported
Please post the actual info.xml file from the i2 drive.
It doesnt look like its talking to the truck, is it in RUN mode when you try this?
Franksbanks06
here you go and yes it was in the 'run' mode
thanks so much!
thanks so much!
Franksbanks06
idk if this helps but after i plug it in to my windows and do the "check for updates" after the update is complete..
it does not restart and or show any updates are being installed. is there a way i can reset whatever corrupted file is in the drive? just something i thought about..
2nd day with me not being able to use it.. kind of frustrated
the device is asking you to connect to a pc and let it check for updates, it will download the vehicle update then you load that to the pcm then you can tune it.Franksbanks06 wrote:here you go and yes it was in the 'run' mode
thanks so much!
Franksbanks06
i have plugged into my pc numerous times....
how can i force the installation of updates before i can disconnect?
( i have left if plugged in overnight)
when i plug it into my truck, it says checking/installing updates, but then goes directly to the disclaimer page and im back to square one.
it doesn't seem to ever restart and or load like the 1st time it had done and or show the load/verify images
