What should i do to optimize towing? I have the 87 tune in now but I've heard to actually take that tune out due to potential issues when towing heavy loads. What are the recommendations for towing with the I2?
Thanks!
Tune for towing
Re: Tune for towing
the tune is fine for towing...
make sure you installed the tune from the Tune Vehicle - ADVANCED MODE menu though, so it's actually the 87 tune..
there's a bug in the easy mode menu, where if you select the 87 octane tune, it actually installs the 91/93 octane tune...
so, if you're only using 87/89 octane gas, then you want to go to Tune Vehicle - Advanced Mode - and select/install the 87 Octane Tune from there..
then You'd just use the tow/haul button on the dash like you normally would. That just tells the transmission to use different shifting settings, that's all it does. The engine tune does not change at all, the engine tune stays the same no matter what mode you're in.
waltheraustin
Re: Tune for towing
06MonteSS wrote:the tune is fine for towing...
so to get the ring and pinion and tire selections in, i would've have to use the advanced menu, correct? i just can't recall if i had to go into advanced or not but I'm fairly certain i would've had to for those advanced selections. Is there anything else i can do with the intune to help with towing?
Re: Tune for towing
yes.. have to go to Advanced Mode.. select the tune you want to install.. select to Modify the tune.. change the gear ratio/tire size, and install the tune.
waltheraustin
Re: Tune for towing
06MonteSS wrote:yes.. have to go to Advanced Mode.. select the tune you want to install.. select to Modify the tune.. change the gear ratio/tire size, and install the tune.
Lew - when i finally get to do the diablew tune, will that be assistance in towing or for regular driving or both?
Thanks again!!
Re: Tune for towing
a custom tune improves everything bud.. like I said above, there's nothing done differently for towing.. You'd just use the tow/haul button on the dash like you normally would. That just tells the transmission to use different shifting settings, that's all it does. The engine tune does not change at all, the engine tune stays the same no matter what mode you're in.
so yes, a custom tune will improve both normal regular driving, and also when you are towing.
waltheraustin
Re: Tune for towing
right on man, thanks! I thought i read that leaving torque mgmt off when towing which i guess is done in your tune and the canned tunes could mess something up. Is that BS?06MonteSS wrote:a custom tune improves everything bud.. like I said above, there's nothing done differently for towing.. You'd just use the tow/haul button on the dash like you normally would. That just tells the transmission to use different shifting settings, that's all it does. The engine tune does not change at all, the engine tune stays the same no matter what mode you're in.
Re: Tune for towing
So should all 87/89 octane tunes be done through the advanced mode.?06MonteSS wrote:the tune is fine for towing...
wehowardjr
Re: Tune for towing
Interesting. I just registered my unit Thursday or Friday and it did not update. Been driving on the canned tune for a week.
