Install loop
Install loop
Recently updated the i2. It went through the update to the press continue to reboot. Once rebooted it installs the update again, over and over stuck in this continuous loop.
Re: Install loop
save this to the i2 drive, et it import then run the updater again and it will be done.pogdl wrote:Recently updated the i2. It went through the update to the press continue to reboot. Once rebooted it installs the update again, over and over stuck in this continuous loop.
