Diablo intune freezing up
hotrod_4x4
Post by hotrod_4x4 »
After plugging in my intune into my truck, its loads up and then after I tap tune vehicle, the little circle starts spinning and then it freezes up right there, it wont do anything after that. its freezes up the same way each time and I don't know what to do.
Re: Diablo intune freezing up
what vehicle?
Please post the info.xml file from the intune drive.
hotrod_4x4
2009 Silverado 4.8
info.xml
(2.92 KiB) Downloaded 386 times
please post the files from the tunes folder on the intune drive and we'll reset it for you.
hotrod_4x4
Will do tonight when I get home
hotrod_4x4
here are the files
TCM_24250663_Backup.grg
(16.11 KiB) Downloaded 510 times
ECM_12631170_Backup.grg
(56.14 KiB) Downloaded 404 times
hotrod_4x4
:shock:
give us a call with the tool powered up so we can reset it or go to settings/advanced/registry reset and type out the key it displays and post it here and leave the tool on that menu until we reply with a password.
hotrod_4x4
I have the tool plugged into my truck right now so it will stay powered on, if this doesn't work I will try to call as soon as I am able.
The key showing is:
ED4C03 45DA4C 076F08 FDBD60 6678A4
Thank you for your time, I hope this works so I can tune again.
click next thenneter this
FA934703552C9CAC
then Ok and it will reset.
hotrod_4x4
That part worked, now it's telling me I need to email you my stock time file. I will send it to the link provided tonight.
you can post it here.
hotrod_4x4
here is my backup file
ECM_12631170_BackupDiabloTune.grg
(55.12 KiB) Downloaded 412 times
hotrod_4x4 wrote:here is my backup file
save this to the i2 drive, let the tool import it then load the update to the vehicle through the advanced menu, then you can reload the tunes, although we may need to do the same for the pcm.
CTRL_12631170_UPDATE_3GCEC13C89G269381.grg
(52.44 KiB) Downloaded 487 times
hotrod_4x4
You got it, I'm back in business, thank you for all your help, I'm tuning again.
