'11 charger R/t traction control disabled
Posted: Sun Feb 19, 2017 3:30 pm
by Peddards
2011 Charger R/T max 5.7, I'm using the T1000 with the most current update of the 91 tune for the car. When ever I try to disable traction control through the programmer it screws up my transmission completely! Cant get the car to shift right feels like it's starting out in 2nd to 3rd gear and will start rolling backwards if I let off the brakes on a very slight hill. Would love to be able to use this feature but it's hard to use when it turns your trans into mush!
Re: '11 charger R/t traction control disabled
Posted: Tue Feb 21, 2017 1:59 pm
thats all you are changing?
Posted: Sun Mar 05, 2017 8:54 pm
by Peddards
I have the 91 tune, the transmission shift increased, and all of that works fine till I turn off the traction control via the programmer
Posted: Mon Mar 06, 2017 12:25 pm
do you get any codes when this happens?
Posted: Fri Mar 10, 2017 2:26 am
by Peddards
Nope no codes at all
Posted: Fri Mar 10, 2017 1:46 pm
never seenor heard of an issue like this.
If you post the last tune written Ill make you a tune that has it disabled permanently and it should work properly.
