Page 1 of 2
PCM Calibration
Posted: Mon Mar 06, 2017 11:50 pm
by wtjoker
Please advise. xml attached. thnx I have tried updating everything for the last 4 hours and I'm starting to drool on myself from exhaustion.
Re: PCM Calibration
Posted: Tue Mar 07, 2017 10:26 am
its not asking for an update, what are you trying to tune here?
Re: PCM Calibration
Posted: Tue Mar 07, 2017 10:36 am
by wtjoker
I get this messag. No parameter adjustments are available and are grayed out.
Re: PCM Calibration
Posted: Tue Mar 07, 2017 10:44 am
click the green check mark then go to the pc and run the updater, if it does not download the file post the new info file here please.
Re: PCM Calibration
Posted: Tue Mar 07, 2017 11:15 am
by wtjoker
I completed that process several times. After clicking the green check box, I then plugged the unit into my pc, it said no updatest needed. I tried this several times, with the same results.
Re: PCM Calibration
Posted: Tue Mar 07, 2017 2:14 pm
Re: PCM Calibration
Posted: Tue Mar 07, 2017 3:47 pm
by wtjoker
connected, no updates, here is the info.xml as of now..
Re: PCM Calibration
Posted: Tue Mar 07, 2017 6:05 pm
by wtjoker
Any ideas?
Re: PCM Calibration
Posted: Wed Mar 08, 2017 9:38 am
its still not asking for an update.
When you click the green check mark does it then ask you to go plug it into a pc?
Re: PCM Calibration
Posted: Wed Mar 08, 2017 10:12 am
by wtjoker
Yes, I will hook it up again shortly to reconfirm.
Re: PCM Calibration
Posted: Wed Mar 08, 2017 9:20 pm
by wtjoker
I checked yes on the programmer when asked if I would like to recalibrate. it then said to unplug and connect to a pc. When I did that, this is what I got. I attached the info.xml again. it appears to have the same date on it? It appears it is the original file and is not being updated like it should when disconnected from the vehicle. Is there a way to manually send/edit an info.xml in this case?
Re: PCM Calibration
Posted: Thu Mar 09, 2017 10:24 am
the request is there now, I will have this fixed shortly.
Re: PCM Calibration
Posted: Thu Mar 09, 2017 11:01 am
So, it turns out this is an odd cal, is this an old Mopar PCM?
Re: PCM Calibration
Posted: Thu Mar 09, 2017 11:03 am
by wtjoker
Re: PCM Calibration
Posted: Thu Mar 09, 2017 2:00 pm
by wtjoker
I spoke with tech support, looks like it wont work with my vehicle. I wanted to be sure I got it correct, the DCX will do 2011-2014 Dodge RAM hemi?
