2005 Silverado gear ratio change
Silverado05
Post by Silverado05 »
I need someone to change my gear ratio please....
old- 3.73 with 305/40/22
new- 4.10 with 305/40/22
Thanks in advance!
Re: 2005 Silverado gear ratio change
It will be monday unfortunately,m the GM tuner is out sick today.
here ya go.. gear ratio set to 4.10...
then just readjust your tire size setting if your speedo is off...
thank you sir :)
mikel wrote:thank you sir :)
you betcha' !! :twisted:
Silverado05
Thanks !
Silverado05
I must have did something wrong, when I plugged the tuner back into the truck it made me select a new tune and wouldn't let me modify the tune I already had. And the ratio hasn't changed
Silverado05
I figured it out. I was trying to paste it in the tune folder, but once I just clicked the file and drug it to the intune it imported it and it worked just fine. Speedo is fixed and no more abs light! Thanks!
glad to hear it.
