Firmware sometimes shows as * not (ok)
Nautique
Post by Nautique »
I have an I-1000 that I just updated to the current Rev and noticed something. I first updated with the original updater and then with the new i2 updater it installed. The updater now shows that no updates are available which I assume means everything is current. After leaving it alone for two hours to make sure it had plenty of time to update and reload, I unplugged it and rebooted and noticed that when I checked the Firmware that some indicated a * instead of (ok.) I have since rebooted it and at times the unit will boot fine and indicates (ok) on all of the firmware info, other time it shows the *. Should I be concerned?
info.xml
(1.07 KiB) Downloaded 418 times
Re: Firmware sometimes shows as * not (ok)
the asterisk means it is still checking that database, shouldn't be an issue.
