loaded tune now wont start cant read pcm to install back up
Posted: Sun Mar 26, 2017 10:28 pm
by deezo
please help i have removed battery cables and and tried everthing i can think of. im thinking i need a new pcm thanks for any help trinity on an 06 ford crown vic
Re: loaded tune now wont start cant read pcm to install back
Posted: Mon Mar 27, 2017 10:39 am
please give us a call with the tool powered up in the car so we can try to recover it.
Posted: Mon Mar 27, 2017 9:56 pm
by deezo
okay, ill try to get off work early in the next couple of days. Im sure you guys are closed by the time i get home central time. you'll be hearing from me soon. thanks
mikel wrote:please give us a call with the tool powered up in the car so we can try to recover it.
Posted: Tue Mar 28, 2017 2:18 pm
by deezo
on hold now, tool powered up, ready to go. lets pray this works :evil_angel:
Posted: Tue Mar 28, 2017 7:44 pm
by deezo
okay first off thank you Shawn with tech support. we got it fixed... but it happened again :oops: :blowup: so im going to have to take another day off work to get with tech again. but i think i know whats happening. it happens when i modify the neutral rpm value. really wish you had an online source to get passwords so i could force the back up again it did not work through the expert menu had to go to troubleshooting restore backup and force it with password . so if i get the code can i call and get a password that will work when i get home, like if i got the code in the morning called at lunch i should be good? thanks for the help by the way, very appreciated. :) :D
Re: loaded tune now wont start cant read pcm to install back up
Posted: Wed Jul 07, 2021 6:53 pm
by juangorena
My friends i have installed a tune on my 2016 3.5 Eco F150 , original back up saved, tune installed i removed the tuner T1000 , turn the truck on , Everything looked ok , press gas pedal twice, everything normal i turned off the truck.
Next time i trĂ­ed to turn on the truck all alarms went on the Dashboard, no mileage shown.
The tuner states that si unable to Get the Vin out PCM
NOW TRUCK DONT WORK , what can i do ?
Posted: Fri Jul 09, 2021 11:43 am
deezo wrote: Tue Mar 28, 2017 7:44 pm okay first off thank you Shawn with tech support. we got it fixed... but it happened again :oops: :blowup: so im going to have to take another day off work to get with tech again. but i think i know whats happening. it happens when i modify the neutral rpm value. really wish you had an online source to get passwords so i could force the back up again it did not work through the expert menu had to go to troubleshooting restore backup and force it with password . so if i get the code can i call and get a password that will work when i get home, like if i got the code in the morning called at lunch i should be good? thanks for the help by the way, very appreciated. :) :D
The code changes each time you access it, so its best to do it all in real time.
