Vehicle not supported?
xX054Xx
Post by xX054Xx »
Completely new to this whole madness. I ended up buying an unlocked intune i2 from ebay. I've updated the tool using both the windows folder updater/ and the ignition updater. However it still says my car isn't supported and requires an update. But when i try to re-update through the ignition program, it attempts to download 4 files but apparently fails.
attached are the SS that i've taken, and the info file?
car: 2006 srt8 charger
Edit: never got the chance to backup any of the stock tunes, so i don't know whats going on.
Untitled 2.png (814.68 KiB) Viewed 30792 times
info.xml
(2.8 KiB) Downloaded 1006 times
Re: Vehicle not supported?
save this to the i2 drive and let the tool import it then load the update to the vehicle then you can tune it.
2B3LA73W96H419733_05030232AF.drg
(512 KiB) Downloaded 1189 times
Bentjudges
Post by Bentjudges »
You should be fine then. The OS on your PCM is already supported.
OksiVeron
Post by OksiVeron »
@xX054Xx
I was had exactly the same problem.The latest version solved this problem.
And everything became supported. Just go to the official website and download the version you need. :o
"Do not dwell in the past, do not dream of the future, concentrate the mind on the present moment."
"My Being and stuff."
