N2O with Trintity 93 Perf tune?
Posted: Wed Apr 19, 2017 12:19 am
by DrmThmpr
Wondering when I install this 75-100 hit of Nitrous to my 5.7 Ram 1500 can I still run the Perf tune I have installed from my Trinity?Or will the timing and fuel ratio be all jacked up? Hoping I didn't just waste money buying Nitrous and or a tuner that won't run in harmony together. Anyone have experience with this?
Re: N2O with Trintity 93 Perf tune?
Posted: Wed Apr 19, 2017 12:42 pm
ideally you should be using the tuner to pull some timing at WOT for use with N2O.
Posted: Thu Apr 20, 2017 9:06 pm
by DrmThmpr
Thanks Mike, I knew that and know it should be around 2 degrees with the 100 shot but....where in the world in the tuner do I pull timing?I don't see that option? Could you explain where in the tuner I do this?
Posted: Thu Apr 20, 2017 9:25 pm
by DrmThmpr
also would I need to make my own tune out of the canned tunes or use original backup tune to adjust?
Posted: Thu Apr 27, 2017 8:26 am
after you select the tune choose the modify tune option, then modify parameters, then you can adjust the timing as needed under WOT spark.
