Calibration not supported
Posted: Thu Apr 20, 2017 10:32 am
by RoadHawg
Trying to install my Trinity into a 2012 Dodge Challenger 5.7. I did the updates and I'm get a message saying my" calibration 05156128AH is not supported. Need to downgrade to 05156128AD in order to continue". Am I missing an update or is it not compatible with my car?
Re: Calibration not supported
Posted: Thu Apr 27, 2017 8:25 am
it wants you to connect to a pc, open the dsdownloader software and look for the calibration updater button. click that and it will download the file you need then you load that to the car, then you may tune it.
Posted: Tue May 02, 2017 8:08 pm
by Abo_Yazeed
I have the same issue with my trinity but defferent numbers
my car is a crysler 2011 5.7
the message is " calibration 68139881AH is not supported. Need to downgrade to 6813988AE in order to continue"
already the trinity was updated with the last file "v.1r13e"
Posted: Tue May 16, 2017 12:31 pm
Abo_Yazeed wrote:I have the same issue with my trinity but defferent numbers
you need to connect to a pc and open the dsdownloader and let it find the tool then click the calibration updater button to get the file it is requesting.
Posted: Mon May 29, 2017 8:38 am
by haythamg
I am having the same issue. I have the latest v.1r13g and when I connect the T1000 to the PC again, it doesn't download anything. Instead it asks for a file from my computer. I have a 2014 R/T Charger. I used the tuner before and it worked without issue.
Posted: Tue May 30, 2017 7:33 am
by cpg
Had similar issue over the weekend. Did some work on the car and had to disconnect the battery. Just in case, I loaded the stock tune to the car before I disconnected the battery because this tuner seems to be a little "glitchy". Did my work, put everything back together and the T1000 says not supported. Hooked the T1000 to the computer, did the update (took multiple tries to work). I couldn't get the correct update on the device from my computer, ended up saving the crom file to my computer and then uploading to the T1000 (took multiple tries to work). Finally got the update on the T1000 and them uploaded to the car (took multiple tries to work).
I'm new to this stuff, and maybe the problems are on me. I would suggest to keep trying until it takes. I don't remember how many tries it took to get the tune back on the car but it was 45-60 minutes of head scratching and repeating the steps. Good luck!
Posted: Wed May 31, 2017 12:00 pm
haythamg wrote:I am having the same issue. I have the latest v.1r13g and when I connect the T1000 to the PC again, it doesn't download anything. Instead it asks for a file from my computer. I have a 2014 R/T Charger. I used the tuner before and it worked without issue.
you are in the wrong mode, go to options/change vehicle type and select the 2011 model and let it reboot then it should work.
Posted: Sat Jun 03, 2017 1:27 pm
by blk01stng
I'm having the same issues on my 2014 ram 1500 5.7. I've plugged it back into the computer several times already. downloaded the crom to my tool and everything and still nothing.
Posted: Sun Nov 03, 2019 9:42 pm
by Cbanach
This is what mine says
