Lost Linux Updater directory..
rhricik
Post by rhricik »
Got the I2 today, along with the ECU. First thing I do is plug I2 into my Linux laptop (don't own Windows or Mac, do have an Android tablet...) then try to log into my wireless lan. It won't accept the Enter button after I enter my password, so I change to the I2 drive, change to Updater/Linux directory and run the Java app. It starts, then immediately disappears! Funny thing is that 10 minutes later, I2 says it is updated and to click "Continue" to reboot, so I do...and get "Please wait..." Let it set there for an hour on that screen, then I pull the USB plug to reboot it. Plug it back in and run Update again, tells me it needs updates, this time, the wireless works, I log in and updates start it gets thru the whole routine again. Wait 90 minutes this time, same result. Figure I'll try the Linux Java app again...NO DIRECTORY!
When I look on the I2, there are no databases on the Database Info screen - nothing at all. The Application info is as follows:
GUI -- 2r01l
Installer -- 2r01e
Updater -- 2r01c
Logger -- 2r01a
I've yet to hook up the ECU to my 2015 Scat Pack - sort of want to make sure the I2 is functional before hooking it up - or is part of the problem that I am not connected to the ECU? Is there anything I can do to fix this? I will attach my Info.xml file...
rhricik
Re: Lost Linux Updater directory..
Post by rhricik »
Okay, managed to get everything updated by just downloading the updates and dropping them in the root of the device. Can someone please copy up the .jar file that was in the Linux directory so I can mkdir Linux and paste it back in on the device? :D
