Dealer Toasted My Tune
Posted: Thu May 11, 2017 7:19 pm
by mpaladino
Apologies in advance if there is a thread on this already. I couldn't find it. If there's one, please provide link...
Took my car in for some warranty A/C repair. Bad actuator. Didn't expect dealer to touch my PCM since the work was A/C related.
I have a feeling they flashed my PCM anyway. I went to make an adjustment to my 93 tune (throttle boost to 3%). Wrote to vehicle, turned key off, then on. No problems. Then I went to start it...
Engine barely started. Error codes everywhere. Timing was WAAAY off. Car basically un-drivable. Thankfully, I was able to restore original backup, and it's fine, however, I can't install a default 91 or 93 tune on the car without everything getting screwed up.
Anyone have a clue as to what's going on?
Re: Dealer Toasted My Tune
Posted: Tue May 16, 2017 12:31 pm
if they had flashed it chances are it would not have let you tune it again.
What vehicle is this specifically?
Posted: Tue May 16, 2017 4:39 pm
by mpaladino
@mikel
2014 Challenger R/T Plus.
When i plug in the Trinity, it boots up and will let me into the Performance/Tunes section. But if I modify my 93 tune, save, write, key cycle and then start, the car will barely start and when it does, it sounds like the timing is way off.
I tried to restore the original saved tune and I can't seem to do that either. Get stuck on "Turn Key Off". Wiper trick doesn't work. I end up having to pull the tuner off the OBD port. Wait 10 seconds, then the car starts, but tuner is still paired.
Should I call tech support?
Thanks in advance.
Posted: Tue May 23, 2017 12:11 pm
what are you adjusting when you modify the tune?
Is it ok if you load the tune without any changes?
Are you adjusting the neutral rev limiter param?
