Predator U7194 Mass Air Flow HZ
Jay021486
Post by Jay021486 »
Hi, I have been told that I need to raise my MAF HZ by 300HZ. How do you make this adjustment on the Predator? I have logged a Run and it shows the Mass Air Flow Sensor HZ through the log but under the adjustable parameters in the Custom tune I cant find anything about the Mass Air Flow Sensor HZ to be able to make the proper Adjustments. Any help with this would be appreciated. Thanks
The model is a U7194 and I am using it on a 2008 corvette Base Ls3
Re: Predator U7194 Mass Air Flow HZ
you can't adjust the MAF with a predator.. you'd need to get a custom tune to have that changed.
Jay021486
Post by Jay021486 »
Is there a programmer such as the EFI live that can handle the things that I am needing to adjust. I kinda thought this was a purpose of a programmer to be able to make changes for aftermarket parts.
