Jeep grand cherokee 2007 fan control
Posted: Sun May 21, 2017 5:11 pm
by m_elkhishin
Dears
I have Jeep GC WH 5.7 2007 which has hydraulic cooling fan. I installed 180 thermostat and I need to set the fan set points to lower degree. It seems that the trinity fan control is missing for this particular model. some guys said that it can be adjusted by HP tuner application by setting the fan type to PWM and then set a parameter "desired engine temperature" to the desired degree. the stock setting is 103 Celsius and I want to change it to 95.
I own the Trinity and I hope it can support this feature.
Re: Jeep grand cherokee 2007 fan control
Posted: Tue May 23, 2017 12:16 pm
so is it a mechanical fan or electric?
Post the backup and last tune written files from your device please.
Posted: Tue May 23, 2017 4:39 pm
by m_elkhishin
mikel wrote:so is it a mechanical fan or electric?
It is mechanical rotating by the power steering fluid pressure. but the ECU controls the solenoids to control the speed.
Posted: Wed May 24, 2017 8:22 am
m_elkhishin wrote:mikel wrote:so is it a mechanical fan or electric?
the fan settings are all lowered quite a bit in the tune, so if thats not affecting the fans its not likely something that can be controlled in the same manner as the electric fans.
Posted: Thu May 25, 2017 3:22 am
by m_elkhishin
mikel wrote:m_elkhishin wrote:mikel wrote:so is it a mechanical fan or electric?
Dear Mikel
Thanks for your feed back. the following is a reply from a jeep owner on other forum. he is describing how he solved the issue. I hope that can help finding a solution.
At last got my Jeep's hydraulic fan to now work as I want.
Used HP Tuner and set the low, med/high activation temps etc, but still did not go to high speed when reaching 100 C as set.
Today went back to the guy who does my tuning and found following:
three hydraulic fan types:
1. two speed
2. three speed
3. pulsed modulated
My Jeep has the pulsed modulated and thus the low/high temp limits are not the controlling settings. There is a selection where the required engine temp must be set, then the fan will attempt to maintain this set temp. Fan speed ramps up to full speed if required to keep this set temp.
The default on my Jeep was 103 C. Brought this down to 95 C and now works like a charm.
Posted: Thu May 25, 2017 7:38 am
let me see what we can find on this.
Posted: Sun Jun 18, 2017 8:05 pm
by m_elkhishin
Hi Mikel
did you find any way to solve this issue?
Posted: Wed Jun 21, 2017 9:18 am
Nothing yet unfortunately.
Posted: Wed May 01, 2019 8:56 am
by Labrat
any word on this? i am running into the same issue and i really would hate to switch over to hp tuners since diablosport is so user friendly.
Posted: Wed Jun 19, 2024 1:27 pm
by Madnesst
Sorry to bump this old thread ,
I bought intune i3 platinum and i love it , but im kinda bummed and i feel a bit misled (i probably should've asked before i bought it ) , that i cant control the hydralic cooling fan , also transmission options are missing from the tuner , but i feel a diference in shifting .
On the official site its said that the device supports those options for the specific model ( jeep wk 2005-2010) but in reality it does not
Posted: Thu Jun 20, 2024 10:31 am
Madnesst wrote: Wed Jun 19, 2024 1:27 pm
can you post the info.xml file from your i3 drive?
Posted: Thu Jun 20, 2024 11:05 am
by Madnesst
mikel wrote: Thu Jun 20, 2024 10:31 am
attached
Posted: Thu Jun 20, 2024 4:47 pm
let me do some digging.
