2013 Ecoboost DTC's
jrspence7
2013 Ecoboost DTC's
Post by jrspence7 »
Hey guys -
Every time i tune my 2013 Ecoboost (doesn't seem to matter which tune) I get the DTC: PCM:C1900: Steering Vaps II Circuit Short. I had this read with a different code reader, and it is showing P0299, Turbo Underboost. Usually i would assume that means something is going on with the truck, but i have not been able to duplicate the issue with the stock tune installed (as in, getting no codes untuned). Any ideas?
Thanks,
Jordan
Re: 2013 Ecoboost DTC's
can you post the tunes from the tunes folder as well?
jrspence7
Post by jrspence7 »
Hey Mike -
When i go into the tunes folder is says folder is empty. Here are the pics from the Ignition updater (attached). I noticed that is says updater missing, but every time i plug it in it seems to download the same file and say up to date - not sure if that is normal or has anything to do with this.
if you restored the stock tune to the truck it will be empty, you need to load the tune back to the truck to get copies of the files.
jrspence7
Post by jrspence7 »
Please see attached
jrspence7
Post by jrspence7 »
Hey Mike -
Any update or ideas on this?
Thanks,
Jordan
jrspence7
Post by jrspence7 »
Post deleted
sorry, I missed the thread. I do my best to get to each and every post here but I occasionally miss a few and I apologize.
We'll look into this now.
DiabloMatt
Post by DiabloMatt »
here you go. load this into the truck and should take care of it :)
briguy2
Post by briguy2 »
I'm getting a c1900 code, VAPS short to ground......87 octane tune, 2013 f150 EcoBoost.....
briguy2
Post by briguy2 »
Got it again today...
briguy2 wrote:Got it again today...
can you post the info.xml file from the i3 drive?
