Updater Problems
Post here with any questions regarding the use of the Ignition updater software for PC or Mac
chrisinAR
Updater Problems
Post by chrisinAR »
Every time I plug my I2 into my computer it downloads the same 5 updates. After it goes through the process I get the attached massage.
raycom
Re: Updater Problems
Post by raycom »
I am experiencing the same problem. I am also having the problem when i try to update via wifi.
mike1976
Post by mike1976 »
go into you computer's files open i2 go to updates and erase the first one
raycom
Post by raycom »
Mike I do not have an update file that indicates updates in the i2 file.
The i2 is still indicating that i have 3 update when i ask to update the i2.
chrisinAR wrote:Every time I plug my I2 into my computer it downloads the same 5 updates. After it goes through the process I get the attached massage.
can you please try updating again and see if it says up to date now?
Return to “Ignition updater”
