CMR connection problem......
I have a U7142. Everytime I open CMR_Dat its acting like it wants to communicate but it won't pull the PID list. I have tried every combination of Com Ports and baud rates on the 3 laptops I have tried it on and in the predator. Anyone have any helpful information?
RE: CMR connection problem......
If you are using a USB-to-Serial cable, did you install the drivers for it? It should have come with a CD.
If so, is the cable showing up in your hardware manager?
Some useful information:
USB-to-Serial cable FAQ
CMR_DAT FAQ
I am working on getting the DataViewer to download and view logs from CMR_DAT Predators so that CMR_DAT is no longer the only solution for the 7142.
CMR_DAT FAQ
johnc <at> diablosport.com
No, I'm using the serial port on the laptop. I'm gonna try to find another cable and see if it works.
Yeah, straight RS-232 should not be giving you problems.
turns out it was the cable thanks......
