Caliber srt4 questions
Qcsrt4
Post by Qcsrt4 »
I recently picked up a caliber srt4, only mod I think it has is an AGP wastegate and I was reading that the diablosport trinity 93 tune will not work with this. I want to raise the boost. I already have the trinity tuner and want to know how can I make this work. Thanks!
Re: Caliber srt4 questions
the pcm uses the stock WG for boost control, so if you want pcm controlled boost, you'll need to go back to a stock WG.
Qcsrt4
Post by Qcsrt4 »
So will I still notice a difference with the 93 tune? and just get a different spring to turn up the boost.
I cant say for sure, as the tune is matched to the boost levels we command in the tune, you may need a custom tune to make it all work properly.
Qcsrt4
Post by Qcsrt4 »
Where would I be able to get a custom tune for it to work? I can manually raise the boost but I would still like to use the tuner if that's possible.
Qcsrt4
Post by Qcsrt4 »
I picked up the trinity tuner from a friend who had it on their 02 tahoe. He does not have the tahoe anymore and the tuner reads the last time did not finish. The original will be restored. O don't have the tahoe to plug it into and I can't figure out how to reset it to work with my caliber srt4.
well, its still married to his truck...any idea how it got that way or why he was unable to restore the stock tune?
Qcsrt4
Post by Qcsrt4 »
He said his computer blew up he thought it was from the tuner (I know it wasnt) but he didn't trust using it after he repaired the tahoe. He no longer has the tahoe.
You can call in and have the device unlocked for $179.
Qcsrt4
Post by Qcsrt4 »
Wow that's unfortunate. Will probably go a different route that won't cause so much problems or money.
