I swapped out stock 3.31 rear end in favor of a good used 3.73 Torsen rear end. I purchased an i2020 to set the appropriate ratio, but have so far been unable to accomplish anything. In fact, the only thing I've managed to do is to lose Race Mode from my driving mode selector.
I have tried the following:
-set axle ratio to 3.73 in advanced settings, Quick Adjust
-enable axle ratio change in stock tune, apply tune (this is when Race Mode disappeared)
-applied 93 octane tune with axle ratio change enabled
-applied 91 octane tune with axle ratio change enabled
I have probably tried the above listed processes at least three times each. The end result is the same each time; One quick accel through 1st and 2nd, almost no response from 3rd, fourth is better but lagging. Turning off Traction Control and Advanced Trac don't seem to improve things either. It must just be in limp mode. I'm still hoping that this can be sorted out with the i2. It would be nice to Race Mode back as well.
Do I just need to get the dealer to re-flash it with the correct ratio?
Thank you in advance for your help.
InterMechanico
