Tune Help
blkplude01
Tune Help
Post by blkplude01 »
Anyone have any tune info for a stock srt8 magnum please need some info life shift points and rev limits etc!!!!!
PerfRacer
RE: Tune Help
Post by PerfRacer »
Well, you don't have many choices with an SRT8. Your only option is "raised shift Points", period. Simply chose that option, and the shift points will be raised 200rpm (shifts will occur at 6400rpm now), and the rev limiter will also be raised accordingly, and automaticly. Some guys have had thier cars "bump" the limiter on the 1-2 shift, and they raise their limiter another 100rpm to correct this.
Now, if you have an '06 SRT, you want to pay attention to where your limiter is set, because you can also chose to adjust your Autostick to not automaticly upshift. This means it would bounce off the limter if held in a gear too long. Again, that's only if you choose to disable the auto upshifting of the Autostick. On '07s and '08s this doesn't matter, because the disable feature doesn't work, or apply to those years. Your Diablo will tell you if you choose that option. I hope that helps...
'15 Challenger SRT with an A8.
Mods to come...
SRT8Tech
RE: Tune Help
Post by SRT8Tech »
Yep, what he said^^^^^. But the funny thing is the autostick disable works on my 07 SRT8 Charger for some reason. I guess I got lucky. I also heard the it doesnt work on the 07-08's.
2013 SuperBee......................................................
