2017 Silverado 5.3
Posted: Sun Aug 13, 2017 6:22 am
by Nsg_89
I have a trinity that came off a 2007 Tahoe it is not married anymore, what do I have to do to tune my 2017 Silverado 5.3 I heard it's different then tuning before due to change in computer is this true? Anything special I have to do? Please information on tuning a 2017 Silverado?
Re: 2017 Silverado 5.3
Posted: Mon Aug 14, 2017 10:05 am
update it, go to vehicle and it will ask you to check for one more update.
go back to pc, run dsdl, it will put tool under remote control then return it to main menu, then you can tune the truck.
Posted: Fri Sep 08, 2017 2:10 am
by Nsg_89
Okay thanks the tune went on worked perfectly I'm curious I believe the truck shifts at 5500-5800 rpms how can I change that and how high can you go without doing any damage? Thanks
Posted: Fri Sep 08, 2017 8:01 am
6 or 8 speed?
if 8 speed there are no trans options unfortunately.
Posted: Fri Sep 15, 2017 9:31 am
by Nsg_89
6 speed. And how do I remove rev limiter not speed limiter but rev
Posted: Fri Sep 15, 2017 11:15 am
you can change the rev limiter in gear/drive.. but you can't change the rev limiter in park/neutral.. that's not a user adjustable parameter.. you'd need to get a custom tune done in order to have the park/neutral rev limiter raised...
Posted: Fri Sep 15, 2017 12:48 pm
by Nsg_89
How high can I set my shift points and rev limit without pushing it
Posted: Mon Sep 18, 2017 10:46 am
thats between you and GM :)
