DataView always crashes when opening 2nd log
Crazyced
Post by Crazyced »
I have noticed that I can't open a second log without having DV crash on me.
I'm running version 3.4.1.4 and use an Intune (not using real time data mode) to datalog an SRT-4. I think this has been going on for a long time.
Here's how to reproduce the issue:
-Open DV
-Click Open log and select a log
-Check at least one PID on the left hand column (or else it won't fail)
-Click Open log again and select a new log.
-Click either Yes or No when asked if you want to save the current log.
*DV crashes with the message "Dataviewer application has encountered a problem and needs to close."
I have noticed that if I follow these same steps with the sample logs (F150 parking lot and F150 short wot), it doesn't crash.
My initial guess is that it might have to do with the fact that I log an external PID (AFR).
Can you guys help? It's not a show stopper but it is annoying.
Re: DataView always crashes when opening 2nd log
post one of your logs please.
Crazyced
Post by Crazyced »
Here go go.
I just tested on my home computer (Win10) but it works fine, it seems to only crash on my laptop that uses XP.
1B3ES66S54D570037_07.log
(1.01 MiB) Downloaded 713 times
Hmm, not sure how much effort I can get them to put into an XP issue at this point, let me see.
Return to “DataViewer/DV2”
