2016 FORD F150 P0299 CODE AFTER TUNE
BOOSSST
Post by BOOSSST »
Hello DS!
My check engine and wrench light comes on and I also received the code P0299 after I installed the 87 Octane tune. When I put it back to stock, I don't get the code anymore. Is there an update to fix this? It seems I am not the only one experiencing this issue.
Code: P0299
Category: Powertrain
Definition: Turbocharger "A" Underboost Condition
BOOSSST
Re: 2016 FORD F150 P0299 CODE AFTER TUNE
Post by BOOSSST »
anyone??
Can you load the tune to the truck then post the files from the tunes folder here as well as the info.xml file from the i2 drive?
Does the code appear right away or only after driving it aggressively?
Any other mods on the vehicle?
BOOSSST
Post by BOOSSST »
How do i find the files you asked for? I don't see any by the title you mentioned.
they are on the i2 drive when connected to a PC.
mikedehm63
Post by mikedehm63 »
i have tried to talk to your tech line with the same issue
after going around in circles with someone who would not address the problem I was having i gave up
can someone with actual knowledge of this system contact me rather than just reading a script .
i would like to send a log file of my truck for evaluation.
this i was told could not be done BUT i could buy a new tuner
can you record a log with the tune loaded then post the log and las tune written file here so we can sort this out for you?
mikedehm63 wrote: Fri Jan 12, 2024 8:16 am i have tried to talk to your tech line with the same issue
I found your call notes from sept, it mentioned this issue popped up after changing manifolds, is it possible there is something that happened at that time that may be contributing?
Return to “Predator Ford Gas”
