2005 jeep Grand Cherokee re-installation of stock tune probl
Posted: Tue Sep 12, 2017 1:04 pm
by iiGooNi3
I re-installed the stock tune 2005 jeep Grand Cherokee 5.7l to update the T-1000. The jeep ran terrible and threw 4 different pcm codes. Updated and re-installed tune its fine. Can not clear pcm codes. Why was the stock tune messed up? How to fix this.
Thanks.
Re: 2005 jeep Grand Cherokee re-installation of stock tune p
Posted: Tue Sep 12, 2017 1:29 pm
by macedo6466
I'm going through the same problems with my 2014 Challenger. I'm getting multiple codes after being
tuned or revert back to stock tune.
In my case: I found out that Chrysler has a PCM update that my Challenger requires. This is the reason
for all my trouble codes. My car has very low performance, it bucks while driving, hard codes, etc.
I first have to update the PCM with Chrysler service bulletin and then update the PCM using Trinity with a new calibration ID.
I also carry with me the Bluedriver OBD2 scanner and works great! It searches for all codes... even dealership codes and clears them too.
Could this possibly be the cause with your situation?
Posted: Tue Sep 12, 2017 1:39 pm
by iiGooNi3
Sounds like it. I did not even try to drive it. I just got the t-1000 yesterday, it had me update or calibrate the pcm, then it let me put the tune on. I reinstall stock tune to put the 1r13k 05-10 chrysler gas revision on it instead of the 1r13 mega crom. All my engine lights are off, the t-1000 only cleared the TCM not PCM codes.
Posted: Tue Sep 12, 2017 11:13 pm
by iiGooNi3
Can i get a more in-depth answer on how to fix this? Chrysler bulletin? Can i use the tuner?
Posted: Wed Sep 13, 2017 12:26 am
by macedo6466
Here is a link where you can check for MOPAR recalls by VIN:
https://www.mopar.com/en-us/my-vehicle/ ... earch.html
MOPAR Service Bulletin:
https://www.techauthority.com/
Click on:
> Online Subscription
> Preview TechAuthority On-line
> What's New In Service Bulletins/Recalls
Unfortunately the Trinity cannot update any PCM reflash required from the dealership. You would either
have to take it to the dealership or use the J2534 flash application process.
I searched through the service bulletin but did not see much on 2005..
This list keeps growing everyday so they probably did away with older models.
What codes are you getting?
Posted: Wed Sep 13, 2017 8:36 am
some 05s will run on 4 cylinders after a flash.
What are the codes?
Usually a simple battery disconnect clears this up.
Posted: Wed Sep 13, 2017 1:19 pm
by iiGooNi3
I cleared the codes, so i dont know. Im going to finish rhis work week then get into it friday morning. Ill post codes if the battery dis connect does not work.
By chance have the T-1000 messed with the cruise control on the 2005 or other 5.7l jeep grand Cherokees? It either does not work at all or shuts off after set.
Posted: Thu Sep 14, 2017 5:06 pm
by iiGooNi3
Hey mike, have you heard of after puting a tune on it messes up the cruise control? 2005 wk 5.7l
Posted: Mon Dec 25, 2017 9:57 pm
by tmarcum
Having the same issues with the Cruise control. Just put the T1000 in my Jeep Grand Cherokee 2005 and no matter what tune I do the cruise will turn off and will not turn back on. It was working find before I tried to uses the tuner. I even went back to the factory tune and it still turns off. The cruise will only turn on occasionally. I am going to try to go back to factory tune and pull the battery and see if that will fix it. Not sure what else to try. Here is what I have:
Auto Connect is ENABLED.
Legacy Connect is DISABLED.
A tool was found on COM4 at 57600 baud.
XML RPC commands are AVAILABLE.
XML RPC protocol version is 1.60
Tool type = 'Trinity'.
Serial number = '6O9SN00-3'.
Part number = 'dcx_gas'.
CROM version = 'dcx_gas-1r13l 12/15/2017 05:44:09 PM boot4'.
Vehicle VIN = '1J8HR58285C732225'.
Vehicle Calibration = '56044555AN'.
Original backup SAVED.
Tool is Married TRUE.
Single user tool FALSE.
Using Class2 Protocol FALSE.
Calibration Updates are SUPPORTED.
A Calibration Update is NOT required.
XML RPC WILL be used for FRG transfers.
Tune compression is AUTOMATIC.
Tune compression is set to ENABLED.
Tool registration is SUPPORTED.
Tool SUPPORTS multiple ECUs.
Tool reports 2 ECUs.
Multi ECU Backups : 1
Marriage VIN : 1J8HR58285C732225
Tool ID :
Desc :
PCM : 56044555AN
Multi ECU Tuning : 1
Name: PCM, TuneID: Perf 91oct, Modified: no, Lock: No, Erased: No
Server:
