2017 F150 2,7eb not all options showing up
fordborn
Post by fordborn »
Just got the i2 today. Updated it as described but when I tune I do not see all options supposedly available. Ignition says it is all up to date.
1. Cannot see option for turning of auto start.
2. Cannot see the mpg tune.
Quick start guide also said that on eb engines the i2 would ask for you to download an "ORI" file. Mine did not.
Quick start guide also said it may ask for a "Calibration Update" mine did not.
I have attached the info file, backup tune and last tune.
Thank s
Re: 2017 F150 2,7eb not all options showing up
MPG tune is specific to 3.5, but any of the provided tunes should show mileage gains when driven sanely.
The aut start/stop feature is in the modify parameter menu under advanced tune.
fordborn
Post by fordborn »
I did not see the option for auto start on/off in advance options. Also missed fan control and revlimiter. See attached spec sheet for my truck and tuner.
fordborn wrote:I did not see the option for auto start on/off in advance options. Also missed fan control and revlimiter. See attached spec sheet for my truck and tuner.
can you post pics of the modify param menu so I can see what you have?
fordborn
Post by fordborn »
OK Here they are.
shows bottom box blank, not sure what if any should be there.
Shows mpg tune greyed or dimmed out, cannot select.
Shows that the modify is greyed or dimmed out, cannot select.
please use the advanced tune menu to access all of the available tunes. If you cant select modify parameters from that menu let me know and I will post an update that should resolve it.
fordborn
Post by fordborn »
As you can see in the picture above I am in the advance tune area and the "Modify" is dimmed or greyed out. You cannot click on it, button doesnt work.
fordborn
Post by fordborn »
OK forget the problems, I found the right places. I just need to go a little deeper in the other menus but found what I needed. Thanks for the help.
