Cannot modify parameters
14_Ram
Post by 14_Ram »
Had to got the the dealer so I put the backup file back on the truck. Now back home, plug the tuner and it tells me it needs an update. So I did the update, then when in and put the Diablo tune in the trucck, after that I put my hemifever custom tune. Then I wanted to change my tire size, when in the tuner and when I get to modify parameters it is grey'd out. I cannot select it... I've tried several thing and I am not able to make any changes to the truck???
This is on a 14 Ram 1500 with the I2
Re: Cannot modify parameters
please post up the info.xml file from the i2 drive so we can check this out.
RLROACH
Post by RLROACH »
I'm having the same problem with my srt I can't even shut off the skip shift the only adjustment I can make are the tire size fan on or off with ac. The only choices I have is easy tune or tire size basically before I could change about anything I wanted including the fan temp since I have a 180 thermostat cold air intake and exhaust and the fuel I can use like 93 octane which is readily available here wtf is going on? :normal:
09 Dodge Ram Hemi Ram box Rocks
11 blackberry Durango awsome collor
RLROACH wrote:I'm having the same problem with my srt I can't even shut off the skip shift the only adjustment I can make are the tire size fan on or off with ac. The only choices I have is easy tune or tire size basically before I could change about anything I wanted including the fan temp since I have a 180 thermostat cold air intake and exhaust and the fuel I can use like 93 octane which is readily available here wtf is going on? :normal:
are you looking in the advanced tune menu?
Thats where you'll find the modify parameter menu.
RLROACH
Post by RLROACH »
That is what I see in the advanced menu. I know everyone else don't know anything but I went through every screen looking for what I wanted and I can change tire size rear axle ratio and Diablo tune or standard tune. Those are my choices. Nothing else and the bad thing is it made me update before I could tune.the biggest reason I bought this was because I could shut off skip shift and adjust my fans to work with the 180 thermostat and now it doesn't it is worthless to me now.
