Help! Tuner won't connect to truck?
So I've been using the Diablo trinity on my Chrysler 300 for 6 months no problems but now that it's off the road for winter I unmarried trinity and want to use it in my 02 Chevy Silverado 1500hd but it keeps saying can't comment to pcm or something similar please Help!!!!!
Re: Help! Tuner won't connect to truck?
Anything aftermarket installed in the truck? i.e did not come from the factory?
You need to make sure anything aftermarket is disconnected/pull the fuse for - anything like aftermarket stereo, subs, amps, nav, alarm, remote start, seat heaters, trailer brake/light setup, etc.. anything like that, their wiring harnesses need to be disconnected/pull the fuses for it before you try to tune anything...
also make sure everything is turned off inside the truck.. lights, radio, heat/fan/blower, do not operate power windows, put your parking brake on, etc...
It has aftermarket radios and trailer break controller I'll try unplugging both those first tomorrow..06MonteSS wrote:Anything aftermarket installed in the truck? i.e did not come from the factory?
