speed limit adjustment
Posted: Sat Mar 22, 2008 8:15 pm
by BADRAM06
u said the new update has a speed limit adjustment but there isnt it still tops out at 110 whats the deal
RE: speed limit adjustment
Posted: Sat Mar 22, 2008 10:32 pm
by Polishammer
I have not tried to check it, but if you go to the tune before loading you can change its parameters, and one of them is speed limit. I have changed it to 120, but did not test it yet.
Are you saying that even after adjusting it above 110 it still tops at 110?
Posted: Sun Mar 23, 2008 8:47 pm
by BADRAM06
under the quick adjust features it doesnt list a speed lmt option it only list idle up and tire size
Posted: Sun Mar 23, 2008 9:08 pm
by Polishammer
It is not under a quick adjust. You have to go to the tune itself. Right before loading it should give you an option to change it, once you select it, you will be able to adjust your speed limit.
Posted: Sun Mar 23, 2008 11:32 pm
by BADRAM06
its not there either. Nm i found it
