Difference between tune?
ramair760
Post by ramair760 »
I just installed my new Diablo Programmer in my 07 Silverado. I noticed that I have two tune options (Preditor tune and 87 oct. tune), what is difference between these tunes?
Thanks in advance.
CANUCKPREDATOR
RE: Difference between tune?
Post by CANUCKPREDATOR »
Predator tune is made for 93 octane gas. Don't use it unless you have a full tank of the good stuff. There are also changes to the timing. There is probably more than just that, I'm just learning this stuff too.
Grumpy_Aero_Guy
Post by Grumpy_Aero_Guy »
I was under the understanding the the "Diablo Tune" is an "at the limit" 91 tune, as a significant proportion of the country doesn't have 93 easily available.
Try 91, and monitor for KR. If you don't get any, you're OK. If you do, advance the timing until you don't, OR run 93.
Not trying to step over you CANCUCKPREDATOR, but I recall being told that by someone at DS.... ????
DSLogRedux.com
jsk06c6
Post by jsk06c6 »
Think grumpy means for you to decrease timing until you dont get any KR.
2006 Victory Red LS2 1LT M6, Halltech Stinger, 4" round B&B Bullets, B&B x-pipe, CCA Catch Can, Aluminum Throttle body spacer, Z51 sway bars
    CANUCKPREDATOR
    No problem Grumpy, like I said, I'm learning. Any information you can provide makes me smarter too. :)
    Grumpy_Aero_Guy
    Re: RE: Difference between tune?
    jsk06c6 wrote:Think grumpy means for you to decrease timing until you dont get any KR.
    right you are.... fingers faster than brain..... :shock:
    DSLogRedux.com
    RE: Re: RE: Difference between tune?
    if you only have 2 tune choices, Diablo Tune and 87 tune, then the Diablo Tune for your application is made for 91 octane gas or higher...
    for me, my diablo tune is made for 93 octane - since I also have a separate 91 octane tune available...
    pseudoid
    Post by pseudoid »
    The DiabloSport Predator U7191 (w/a "Born" date of 08/29/2007) for my '06 GTO came with four (3+1) different tunes:
    *Diablo Tune
    *91 Oct Tune
    *Factory HP Tune
    *Original Backup
    I sure would love to know what the differences between the top 3 tunes are.
    Especially helpful would be some dyno graphs comparing each to the OEM tune.
    I also would like to figure out if there is a depository for other tunes for my application,
    Once I was told that there was a 87 Oct tune but I never got to find it!
    Any suggestions would be greatly appreciated!
    Regards,
    2006 GTO LS2 6-speed
    there is no 87 tune for our performance cars...
    diablo tune is for 93 octane
    91 is for 91 octane
    factory hp tune is used to make adjustments to your original/stock tune
    difference is that the higher octane tunes have more aggressive air/fuel mapping and more advanced timing/spark advance.
    sickREDsierra
    Post by sickREDsierra »
    my girlfriend would love you!! :lol: :lol:
    2007 Sierra, 370 C.I. , Custom CompCam, ProEdge 3600 converter, 4.11's with eaton LSD, Foose 20's, DynoTune Nitrous, Patriot CNC'd heads
