i2 WIFI connection problem
i2 can connect with the PC but the device's WIFI will not see any WIFI to connect to, the device is up to date. Any ideas??
Re: i2 WIFI connection problem
so never shows wifi networks in the list?
correct mikel, the top centre shows wifi but under that nothing,
give us a call and we can swap it out for you.
That sounds great mikel but I'm in Australia, how will this work?
Yikes.
Well that complicates things.
We can still swap it out if you wish. If wifi is something you would really like to have working then its worth the effort. If you can get by updating with a PC, then its good to go.
Could it be a FW problem?
No, firmware is same for all devices.
Hay Mikel with my i2 wifi not working will you guys offer me a deal on the new i2?
csambhudat
I have the same issue but I thought it's because the I2's cannot see or use 5Ghz routers, only 2.4Ghz. Even if you run in hybrid 2.4/5Ghz mode the device will not see it. This is true for alot of other (older) devices.
Does the new i3 recognize 5Ghz routers now?
that's a good point, I'll setup an old 2.4GHz router and see what happens.
yeah, I have mine connected to my 2.4ghz channel and have no problems at all with it..
I never even tried my 5ghz channel, because I only use the 5ghz channel for all of my PC's and streaming tv's, that's it... everything else - phones, tablets, tuners, etc. all get set to the 2.4ghz.
Just done an update to the i2 device and now when I press wifi setup the device stalls and the only way to get it back working is to unplug the device, I can see connection info like device MAC address and the like but once I press wifi set up it's dead.
Looks like my i2 can not connect to a network if the network is hidden.
