Data logging speed?
04GTNNC
Data logging speed?
Post by 04GTNNC »
Why when i view my data on the pc does it not play in real time? Everything is running at double time!
johnc
RE: Data logging speed?
Post by johnc »
If you hit the fast forward key/button during playback it will double the speed. Just hit play again to return to normal speed.
johnc <at> diablosport.com
04GTNNC
Post by 04GTNNC »
I understand that! but it plays fast (not real time) when in play, fast forward speeds it up even more. If i have a 8 min log it runs through in less than a minuet. I have to pause and do segment by segment to read data, this also occurs on the CMR_DAT. I have the u7146 04 mustang.
johnc
Post by johnc »
Ah, I get it. This was a log recorded on the Predator and then downloaded to the DataViewer. The timestamps in the logs created by the Predator must have issues. I will look into this on Monday, I may have to add a widget to the DataViewer to correct the timestamps.
What is the revision of your 7146? The revision is at the top of the main menu.
04GTNNC
Post by 04GTNNC »
its v.7r50d > and thanks for checking it out! And do you know about the logredux program that was posted. It seems that would help me learn more but it keeps telling me that i have to select the equivalence ratio when i try to verify the parameters!
04GTNNC
Post by 04GTNNC »
any word on the timestamps?
johnc
Post by johnc »
I've asked around, and nobody else has reported this error. Can you send me one of your log files? Zip it up and email it to the address in my signature, if you would.
johnc
Post by johnc »
Ok, one developer responded and said he had heard of it, and that it is a problem that is fixed in the new version 9 release that is in testing right now.
04GTNNC
Post by 04GTNNC »
OK john, I emailed to logs to you.
04GTNNC
Post by 04GTNNC »
johnc
Post by johnc »
I replied to your email with an email.
04GTNNC
Post by 04GTNNC »
hmm.. not sure why i didn get it! Its [email protected]
johnc
Post by johnc »
Yup, that was the Reply To address: [email protected]. Resending this morning.
Return to “DataViewer/DV2”
