Smog test failure
Posted: Tue Nov 28, 2017 4:59 pm
by JohnBorg158
have a 2004 SRT4, larger turbo, injectors, and custom tune, failed smog plug in test. TUNER had 02 sensor delete and wrote a tune only for the test. By the way cat delete. Downstream 02 sensor has a spacer. Drove the car 60 miles and still the same. See attached pdf for test results/
Please helpppppp Have diablo 7134
Re: Smog test failure
Posted: Mon Dec 04, 2017 12:46 pm
did you drive around long enough to set the monitors after loading the new tune?
Posted: Mon Dec 04, 2017 6:33 pm
by JohnBorg158
mikel wrote:did you drive around long enough to set the monitors after loading the new tune?
yes I drove 200 miles and still same failures
Posted: Mon Dec 04, 2017 6:54 pm
amount miles doesn't matter as much as the number of "drive cycles" that have been completed..
