'15 F150 2.7 EcoBoost Start/Stop not working
flightwatch
Post by flightwatch »
Hi. Fantastic tune btw.
I cannot get the auto start/stop function to disable. I have selected it in the advanced options menu and applied the tune 3 separate times. Every other parameter is loading correctly from what I can tell. Any thoughts?
Re: '15 F150 2.7 EcoBoost Start/Stop not working
please post the files from the i2 drive/tunes folder so we can check it out.
flightwatch
mikel wrote:please post the files from the i2 drive/tunes folder so we can check it out.
Sorry for the delay in getting this to you. I have been incredibly busy with the new year. Anyways, here is the tune file. Also, both my Ignition software and my i2 updated today. I'm sure that it was up to date when I flashed the tune to my pick up, but would that might be the cause of the auto start/stop not disabling?
Im told this is fixed here, please restore the stock tune then load this update to the i2 drive and let it import the file then you should be able to disable it yourself.
flightwatch
mikel wrote:Im told this is fixed here, please restore the stock tune then load this update to the i2 drive and let it import the file then you should be able to disable it yourself.
Thank you. I'll try it out and report back.
