initial tune and retune question
Posted: Mon Jan 01, 2018 5:37 pm
by chile
Hello,
I have 2009 Silverado with a 5.3L. I recently bought a intune to give a tune and change the tire size. I had to update twice before it would recognize my truck. It was able save the stock ECM and TCM (which i can see when hooked to my computer). Then it loaded the tunes with the changed parameters I put in i.e. tire size, firm shift, and shut off DOD. But then after writing and loading tune. It said failure occurred writing fail log.
The truck does fine and appears the tune is working. After that I tried log some driving around and the intune froze. I tried to put the truck back to stock and it froze again. I want to retune it to change some other things. I'm afraid to try to update it and lose the stock tunes.
Any info will help alot.
Re: initial tune and retune question
Posted: Tue Jan 02, 2018 12:53 pm
please post the info.xml file from the intune drive so we can check it out.
Posted: Tue Jan 02, 2018 10:29 pm
by chile
I was also wondering if I should reset the the adaptive trans table.
Posted: Wed Jan 03, 2018 9:15 am
by 06MonteSS
there is no adaptive trans setting that you can adjust/reset...
Posted: Thu Jan 04, 2018 1:11 pm
by chile
I know that thru the intune you cant but I have access to a snapon scanner.
Posted: Fri Jan 05, 2018 8:56 pm
by dmoore
my tuner did same with no updates has this been solved
Posted: Sat Jan 06, 2018 1:05 pm
by chile
Nothing Yet. Afraid to try to update it.
Posted: Sun Mar 18, 2018 5:41 pm
by chile
So my intune keeps freezing. When I trying to do anything from adjusting some parameters or returning back to stock. I go to the "turn you ignition key on dont start your engine" screen. Then the circle spinning thing stops. It even stops when I try to datalog. I searched and saw that there might be reset for the registry. Any help would be great thanks.
Registry number : FF2EC3 3B1706 2BC6E6 36F288 CDF844
