2003 Dodge Ram 5.7 misfires what PID to log?
Migander
Post by Migander »
I have a 2003 Dodge Ram 2500 with 5.7.
Feels like I am dropping a cylinder.
Would like to log fuel trims and misfires.
Any idea what PIDs to log?
Assume if my fuel trim is constantly adjusting, going rich then leaning out that would be lack of spark,
This would show as misfire as well?
What PID logging could indicate a bad injector?
--Charlie
2003-Dodge RAM-2500-Quad Cab-5.7-automatic-4WD-3.73:1, using I-1000
Re: 2003 Dodge Ram 5.7 misfires what PID to log?
fuel trims are always adjusting, thats normal.
PIDs will be labeled misfire, should be a specific misfire group.
Tough to see a bad injector from one pid, but if you have a misfire in one cylinder move that injector and see if the misfire follows it.
Migander
Post by Migander »
On the Tuner when configuring PID's if I select the "misfire" PID it jumps back to the PID configuration screen but does not add "misfire".
Should I be able to log this on a 2003 Ram 2500 5.7?
please post the info.xml file from the i2 drive so I can check this out.
Migander
Post by Migander »
See attached file.
info.xml
(1.94 KiB) Downloaded 339 times
Migander
Post by Migander »
file posted
